Wheels damaged at discount tire shop
2nd Gear
Hi Folks, I have been wracking my brain trying to locate information on the web about repairing versus replacement of polished aluminum wheels. I noted that someone with a little road rash on the side of their wheels inquired in the forum about having their wheels repaired by a cnc lathe but my situation is a bit more involved than that.
When I took my C5 to tire shop the technician used a wire wheel grinder to remove the balancing strip that was affixed to the wheel by adhesive, rather than using a adhesive solvent to remove them. My wheels now have gouges on the inside flat surface the slightly longer than the length of the former balance strip and the tire store insurance rep is recommending repairing my wheels versus replacement.
My concerns are:
won't removal of that much material compromise the structural strength of the wheel, and doesn't that change the color of the wheels to a bluish tone as a result of the heat of the cnc, AND if a cnc is used to hone the wheels down doesn't this change the appearance from polished to machined?
I am a former insurance adjuster retired due to disability. All the reference sources I used to have with ICAR are no longer available to me.
Any and all recommendations, website sources and or documentation is greatly appreciated.
My concerns are:
My concerns are:
My concerns are:
Would help knowing where you live to give you more help, but team 3 wheels in San Leandro, Ca (S.F. Bay Area) does a really nice job at repairing wheels.
2nd Gear
