Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Help with tire size
Old 05-24-2014, 12:48 PM
jbutler
Support Corvetteforum!
jbutler's Avatar
Default Help with tire size
I have found a set of Cragar rims and tires but need help determining the fitment.
My car is stock 64 coupe.
The information I got from the seller is this;
GM bolt pattern
Front 15 x 7 backspace 4.25 offset +6mm
Rear 15x8 backspace 4.5 offset 0
The tires are Goodyear Polyglas GT F60-15
Any help is greatly appreciated!
Thank you
Jim
Old 05-25-2014, 02:51 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
First of all, those tires are SO old, I wouldn't use them for road duty. I never had a C-2 Corvette, as I was a little too young, but a couple of my older friends did have them back in the day. To the best of my recollection, a 7" rim is pretty much the MAX you can use, and a current tire would be sized something like a 205 or 215/70/15.
Secondly, clearance between the rear of the spokes and the calipers is critical. A lot of wheels have issues there. And as if that isn't enough, I heard stories of body bolts having to be loosened, and the body shifted on the frame, for tire clearance, as it's THAT close.
Remember, these cars were designed around MUCH narrower tires....
Old 05-25-2014, 03:43 PM
jbutler
jbutler's Avatar
Thanks. That matches what other have said in the C2 forum.
Old 05-25-2014, 05:00 PM
leadfoot4
leadfoot4's Avatar
Didn't trust their opinions??
Old 05-29-2014, 09:54 PM
jbutler
jbutler's Avatar
Hahahahahahahaha.....
Nothing like that. I posted on both forums, the C2 guys just responded faster....
Thanks to all.
Still looking for a set of wheels for the '64......
Jim
To Help with tire size
Quick Reply: Help with tire size
