18x10 F & 18x11.5 R on C5Z?
I'm toying with running this size CCW C14 Corsairs. Anyone run this set up? How do you or did you like them? Also what size tires did/are you running?
This would be for the street mostly - I love the look of wide wheels.
thanks
thanks
I've got the Big Street Classics in the same sizes left over from my c4. They need tires before I can test fitment but they were made for c5. I have read that 335/30's should fit without wide body or tub but I don't believe it! My 325/30/19 Invos on 19x11's barely fit and sometimes rub the inner fender well lining a little and Invos run narrow, like 12.6". Mine is lowered on stock bolts.
Are you planning on putting the classics on your C5Z?
Maybe, but it's just the inner fender liner not worried about it. Not a Z, but I'm planning to have 2 small dings fixed on one of the fronts, then try some plasti-dip on them to experiment with different blacks/grays. I may sell them depending on the results cause I really like the dark gray c6 wheels on my black c5.
