Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Formula 43 RAD10 18" CCD Club Sport Wheels
Old 05-06-2015, 07:40 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Old 05-08-2015, 08:31 AM
Former Vendor
St. Jude Donor '13
Old 05-11-2015, 07:55 AM
Former Vendor
St. Jude Donor '13
WHEEL & BIG BRAKE KIT PACKAGE w/Grille mounted cooling & Motul RB600 Brake Fluid
The Formula 43 Advantage
Blind fastener technology with Rolled formed
Threads and Military Grade Bolts
SAE J2530 Aftermarket Wheel Certification
and Motorsport Load Tested
Wide Range of Fitments
Custom offset, width and brake clearance options
Drop center contour for proper TPMS fitment
All wheel components manufactured in the USA
BREMBO GT SYSTEMS
Kit Fits factory Wheels
Front kit contains:
Two 6-piston monobloc calipers (Red)
Street performance brake pads
Two 2-piece floating type III slotted rotors 13.8”/350mm diameter
Front Goodridge stainless steel braided brake lines
Adapter brackets
These 6-piston monobloc calipers have more brake torque using a wide annulus, kit uses the VERY high thermal 34mm thick rotor ring with 72 vanes.
05-13 Corvette C6/ZO6/GS/ZR1 Front Grille Mounted Brake Cooling Duct
XP Motorsports 05-13 Corvette C6/ZO6/ZR1 Front Grille Mounted Brake Cooling Duct System
Everything you need to install grille mounted brake cooling in your C6 Corvette. The ducts fit behind the front grille no need to lose your fog lights. The ducts mount on the inner grille support (triming of the support is required). For ease of installation removal of the front bumper is required.
Formula 43 Rad 10 CCD Club Sport 18x11/18x13 Set of 4 05-13 Corvette ZO6/C6 Brembo GT Brake Kit
Package Includes
(2) Front 18x11 Rad 10
3 piece Wheels Correct Backspace C6/ZO6 (Black)
Clears Brembo and Large Brake Kits
(2) Rear 18x13 Rad 10
3 piece Wheels Correct Baclspace C6/ZO6 (Black)
(2)Brembo 6-piston monobloc calipers (Red)
Adapter brackets
(2) Large Brake Duct Vents
(2) Spindle Mount Brake Hose Adapters
(2) 3" Hose Clamps
(10Ft) High Temperature 550 degree Silicon Brake Hose
Mounting Screws and pop rivets
(2) pints Motul RB600
http://www.xplosiveperformance.com/B...GS_p_3631.html
$7795.95
Old 05-13-2015, 08:14 AM
Former Vendor
St. Jude Donor '13
Old 05-18-2015, 07:54 AM
Former Vendor
St. Jude Donor '13
Old 05-20-2015, 07:36 AM
Former Vendor
St. Jude Donor '13
Package Includes
Adapter brackets
(2) 3" Hose Clamps
$7795.95
Old 05-22-2015, 07:47 AM
Former Vendor
St. Jude Donor '13
Package Includes
Adapter brackets
(2) 3" Hose Clamps
$7795.95
Old 05-26-2015, 08:18 AM
Former Vendor
St. Jude Donor '13
Package Includes
http://www.xplosiveperformance.com/F...6-_p_3508.html
Starting @ $3629 Delivered lower US
Old 05-28-2015, 08:19 AM
Former Vendor
St. Jude Donor '13
Package Includes
BREMBO GT SYSTEMS
Front kit contains:
Adapter brackets
Package Includes
Adapter brackets
(2) 3" Hose Clamps
$7795.95
Old 06-01-2015, 07:59 AM
Former Vendor
St. Jude Donor '13
Package Includes
Old 06-03-2015, 08:59 AM
Former Vendor
St. Jude Donor '13
WHAT IS FORMULA 43?
The Spin-Form process developed by Formula 43 is a specific method in spinning 6061 aluminum circular sheets into 2 piece rim-halves. The computer controlled German spinning machine uses "4" rollers to form the inner and outer rim-halves on tooling designed in the shape of each rim-half. The Formula 43 method is a "3" step process:
(1) spinning the part.
(2) heating and aging the 6061 rims to T6 condition and
(3) re-calibrating the rim-half
This exclusive process is known as: FORMULA 43
Package Includes
WHAT IS FORMULA 43?
Package Includes
BREMBO GT SYSTEMS
Front kit contains:
Adapter brackets
Package Includes
Adapter brackets
(2) 3" Hose Clamps
$7795.95
Old 06-09-2015, 07:40 AM
Former Vendor
St. Jude Donor '13
WHAT IS FORMULA 43?
Package Includes
Old 06-11-2015, 07:36 AM
  #33
Former Vendor
St. Jude Donor '13
Package Includes
Old 06-15-2015, 07:54 AM
  #34
Former Vendor
St. Jude Donor '13
WHAT IS FORMULA 43?
Package Includes
Old 06-17-2015, 08:34 AM
  #35
Former Vendor
St. Jude Donor '13
WHAT IS FORMULA 43?
Package Includes
Old 06-19-2015, 07:52 AM
  #36
Former Vendor
St. Jude Donor '13
WHAT IS FORMULA 43?
Package Includes
Old 06-24-2015, 08:41 AM
  #37
Former Vendor
St. Jude Donor '13
WHAT IS FORMULA 43?
Package Includes
Quick Reply: Formula 43 RAD10 18" CCD Club Sport Wheels
