HPDE cheep wheels for a C7
What wheels/tire combo are your all running for track days?
I is it safe to drop to 18's in the front and 19's in the back? More track tires are available in this size.
Thanks!
Thanks!
Here's the most likely setup:
Front, 18 x 9.5, 56mm to 52mm, 265/35-18 tire or 275/35-18 tire
Front, 19 x 9.5, 56mm to 52mm, 275/30-19 tire
Rear, 19 x 11, 79mm to 73mm, 305/30-19 tire
Some of those with 305/30-20 rear tires had rubbing when they lowered the car.
Cheap wheels ? There's a new Cray 2014 line in the above sizes but the 18" wheel is said not to work on the front of a C7 Z51.
Oz Superleggera III in those sizes are about $900 each. The C7 front wheels are listed as C5 wheels while the C7 rear wheels are listed as C6 rear wheels. Use a 3mm spacer with the 59mm front wheel to make 56mm.
Finspeed custom wheels start at about $900 each.
Forgestar custom wheels only makes those sizes in 19/20 and at about $500 each
I'd be a little cautious about putting "cheap" wheels on a track car.....
Received 8,930 Likes
Bill
