Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Help me decide on new tires stock or 255/40/18 295/35/19
Old 09-25-2015, 09:05 AM
skar
skar's Avatar
Default Help me decide on new tires stock or 255/40/18 295/35/19
Need new rubber . ( maybe wheels also)
I now have a 2008 C6 auto. ?
Should I stick with stock size or
are the 255/40/18 295/35/19 a better tire combo for a LS3 auto. pros and cons please.
Sorry for the kind of repeat post but did not get much info out of my last one.
And did not get a lot on search.
Lot of $$$ on super sports I want to get it right the first time.
Old 10-05-2015, 07:44 PM
skar
skar's Avatar
No one chiming in.....?
By that I think I should stick with stock size.
Old 10-18-2015, 08:58 AM
skar
skar's Avatar
Bump. Still no Replies .
Old 10-24-2015, 10:26 PM
nch209
nch209's Avatar
I was hoping for some replies too... Exact same situation with 2008 z51 m6. Any help, or has op made the leap and have any opinions??? Thanks!!!
Old 10-25-2015, 05:24 PM
skar
skar's Avatar
Default From discount tire
..Name:  image.jpeg
Old 10-25-2015, 05:28 PM
skar
skar's Avatar
Default #2
Old 10-25-2015, 05:32 PM
skar
skar's Avatar
Bigger should be more friendly to saving your wheels . (Road rash)
Not sure on performance gains or losses .
Please chime in .
$1500 for rubber what to make best decision .
Old 10-30-2015, 10:24 PM
C6-Sage
C6-Sage's Avatar
It would be slightly taller, effectively lowering your gearing, and make you a tiny bit slower. Probably unnoticeable though.
The change is so minor that I wouldn't bother unless the tires are cheaper than stock size or unavailable in the stock size. For example, I have noticed some tires unavailable in 285, like nitto drag radials.
Old 10-31-2015, 04:10 AM
B Stead
B Stead's Avatar
RE-11 Tires or the Super Sports
Front, 265/35-18, 25.3" diameter, calls for a 9.5" wide wheel
Front, 275/35-18, 25.6" diameter, calls for a 9.5" wide wheel
Front, 275/30-19, 25.6" diameter, calls for a 9.5" wide wheel
Rear, 305/30-19, 26.3" diameter, calls for an 11" wide wheel
Oz Superleggera III Wheels
Front, 18 x 9.5, 59mm, use 3mm spacer, listed as a C5 front wheel
Front, 19 x 9.5, 59mm, use 3mm spacer, listed as a C5 front wheel
Rear, 19 x 11, 75mm, listed as a C6 rear wheel
Old 10-31-2015, 09:24 PM
skar
skar's Avatar
Thanks guys but that said
? Stick with stock over the 255 / 295 combo .They are $200 cheaper .
And will not lose gearing .
Old 11-20-2015, 06:33 PM
skar
skar's Avatar
Ok ordered new 2014 oem 5 spoke chrome wheels (stock size 18/19" )
Still on the fence on which tire size to go with for my c6
? Stick with stock or go bigger 255/40/18 295/35/19 for a LS3 auto.
Will the wider tire help protect my new wheels from curbs .
Will the taller tire kill my gearing over stock .
Old 11-28-2015, 04:48 PM
skar
skar's Avatar
Ok I went with stock size . Mitchlen super sports zp.
And in south east Michigan discount tire
Nobody could beat them price . I hope I made the
Correct decision not going with run flats .
To Help me decide on new tires stock or 255/40/18 295/35/19
Quick Reply: Help me decide on new tires stock or 255/40/18 295/35/19
