best size r888s for18x10.5 speedlines c6 base
Guys with experience,
I'm going to order R compounds for 2009 c6. I have 4 18x10.5 speedline wheels. Can I fit 295x30x18 toyo R888's in front with no issues?
Thanks in advance
Chuck
Thanks in advance
Chuck
A C7 has minor problems with a front 315/30-18 on that wheel. I think that means no lowering on stock bolts. If the car is lowered then the suspension should also be stiffer.
Here are some other wheel sizes for a C6 or C7:
Front, C5 Z06 rear wheel, 18 x 10.5, 58mm
Rear, Oz Alleggerita, 18 x 11, 75mm, listed as a C6 rear wheel
But there's nothing wrong with an 18/19 setup or even a 19/19 setup.
Oz Superleggera III
Front, 18 x 9.5, 59mm, use 3mm spacer, listed as a C5 front wheel
Front, 19 x 9.5, 59mm, use 3mm spacer, listed as a C5 front wheel
Front, 18 x 10.5, 59mm, listed as a C5 rear wheel
Front, 19 x 10.5, 59mm, listed as a C5 rear wheel
Rear, 19 x 11, 75mm, listed as a C6 rear wheel
Oz Superleggera III
