Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Z0-6 wheels on a narrow body, what tires would fit?
Old 01-15-2016, 02:29 PM
cmonkey713
cmonkey713's Avatar
Received 1,252 Likes on 916 Posts
Default Z0-6 wheels on a narrow body, what tires would fit?
Can C-6 Z0-6 wheels be used on a narrow body C-6 provided the tire size is adjusted to fit the fender wells. I would think the smaller width tires would require a slight"stretch" to fit the wider wheel and to allow for the fender clearance. What would the tire be to work? I have seen this done but don't remember the tire size that was used. Thoughts!
Old 01-15-2016, 04:19 PM
EVRGRN
EVRGRN's Avatar
C6 Z06 wheels with C6 Z06 offsets will stick out past the fenders regardless of the tire on them.
C6 non Z06
Front 18 x 8.5, +56 mm offset
Rear 19 x 10, +79 mm offset
C6 Z06
Front: 18 inch x 9.5 inch, +40 offset
Rear: 19 inch x 12 inch, +59 offset
Given those numbers, the Z06 rear wheels would stick out more than 1-3/4" further than the C6 coupe/vert wheels. The fronts would stick out a little more than an inch.
There are previous threads on this, and you may even find some pictures still hanging around. I am big on the flush look, but these are way past that.
cmonkey713 (01-15-2016)
Old 01-15-2016, 04:27 PM
VETFEVER
Support Corvetteforum!
VETFEVER's Avatar
lots of threads on this question.
the fronts can be made to fit by using smaller tires, the rears will stick out. Don't do it...
To Z0-6 wheels on a narrow body, what tires would fit?
Quick Reply: Z0-6 wheels on a narrow body, what tires would fit?
