Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Volk G25 wheels for the C6/C7
Old 02-07-2016, 05:53 PM
B Stead
B Stead's Avatar
Default Volk G25 wheels for the C6/C7
A couple of merchants claim a special production run of Volk G25 wheels for the C7 and are taking orders.
Volk G25
Front, 19 x 9.5, 55mm, 5 x 120.65
Rear, 20 x 11, 69mm, 5 x 120.65
Well, at less than $1,000 each that is a good buy.
I would rather see the rear wheel at 75mm wheel offset. To get a 305/30-20 tire on at 69mm rear wheel offset will probably require increased rear camber.
Actually, I would like to see a 19 x 11 79mm rear wheel for the 315/30-19 Pilot Sport Cup 2 and then a 19 x 10.5 56mm front wheel for the 295/30-19
Old 02-29-2016, 06:03 AM
hqbrian04
hqbrian04's Avatar
Volk G25
I got my set last month. Looks great.
I got toyo r888 in 265/35r/19 front
315/30r/20 rear. Ill post more picture once i install them on the car.
Its not installed on my car yet. Just took photo next to it.
Old 08-22-2016, 05:13 PM
Bad_AX
Bad_AX's Avatar
May I ask where you got the Volk wheels to fit your Corvette? I am interested in running the Volk Racing ZE40 on my C6 Z06, but need to see if this wheel can be supplied in the correct offset, lug pattern/diameter and hub diameter.
Old 08-22-2016, 05:39 PM
hqbrian04
hqbrian04's Avatar
volk makes c7 spec for g25s
Bad_AX (08-22-2016)
Old 03-21-2020, 02:52 PM
ROME
ROME's Avatar
I think I was the first person in this forum to install 335/30/18’s without fender flares...way back in the day. It took a set of aftermarket trailing arms and custom made trailing arm brackets, but it can be done!
Old 05-26-2022, 07:38 AM
Virginc4r
Virginc4r's Avatar
Default Nice!!!
But c'mon...details...details. What suspension are you running coil springs or shaved rubber cushions on factory spring? Also what type of wheels are those?
To Volk G25 wheels for the C6/C7
Quick Reply: Volk G25 wheels for the C6/C7
