What are the widest Wheels you can fit on a C5 Z06??
Try searching for this but this f****** forum is totally POLLUTED with vendor threads all over the place and makes it very diffucult to get any reasearch done. Theres shouls be only ONE sub forum for them...
Now, what are the widest wheels you can fit in the back of a c5 zo6??
Former Vendor
Former Vendor
My answer to help you is : 315 for 18x10.5 Speedline wheels but you could do 11 wide or even 11.5 . It really/only depends on the tire width . They fit perfect and anything wider will stick out . I've done 335-30-18 on 18x12 and 345-30-18 on 18x12 , looks good but sticks out and you need to be careful not to pinch quarter panels.
I've got some tires to fit that gap , if you looking. See my post in : wheels and tires section or autocrossing. Good luck with your fantasy.
I have CCW Classics on my car, 18" front and rear. My front rims are 10" wide and my rears are 11" with nothing hitting. 265/35 and 295/35 tires, Conti dw's.
I ran a 335/30/18 on mine....in fact they will be for sale soon
Well, tubbing a C5 is just about the easiest thing ever. It involves cutting and re gluing, and putting down a 1 inch strip of fiberglass. The real issue with a 335 on an 18" wheel is if you keep it inside the fender, the inner wheel lip will rub the leaf spring. This means coilovers. The pic below has custom widened 18x12 stock rears with 335s.
hmmm....never tubbed mine...lowered and didn't have an issue
