AMT Motorsport Hub Centric Wheel Spacers - buy ARP studs and get free install!
Supporting Vendor
Now Available - 3/4'' and 1'' Hub Centric Wheel Spacers from AMT Motorsport
Wheel spacers can serve two effective purposes - making your wheels sit hella flush with your fenders, but more importantly they effectively lower the car's center of gravity by widening the track of the car. Ever seen an F1 car that wasn't built as low and wide as the rules allow? Of course you haven't. Get your car wider with either .75'' or 1'' spacers. These spacers will require longer ARP studs which we stock and can ship with your spacers. These spacers will fit all Corvettes C4-C7 as well as many other GM vehicles.
SPECIAL OFFER - Buy a set of wheel spacers and ARP studs and we'll install the studs for free. Just send us your hubs off of your car and we'll press out your old studs and press in the new ones.
These spacers are made from 6061-T6 aluminum. They are turned in our CNC lathes with less than .0005'' run out. We then mill the holes and pockets in one of our CNC mills. The hole tolerances are kept tight for solid fit on the studs, and the pockets are milled just in the name of weight savings. 3/4 lbs is saved per part by the extra milling operation, and the parts weigh 1lbs and 1.2lbs each respectively. Finally the parts are black anodized to protect against corrosion from the elements and engraved with our logo so you're reminded you bought the best wheel spacers available.
Pricing is $230 per pair for the 3/4" spacers and $260 per pair for the 1" spacers. We have the 3.25" long ARP studs in stock and selling for the lowest allowed price of $35.88 per package and as mentioned above buy a set of spacers and studs and we'll install the studs for free!
Click Here to Buy now from our website. Enter Code 'CFRacing' at Checkout and save 10% off the spacers!
Thanks all for looking! Please post or PM with any questions!
