C6 Corvette: How to Remove Front Bumper
Is your front bumper cracked or otherwise damaged? Do you want to install a custom bumper that gives your C6 a more aggressive look? Whatever the reason, read on to learn how to properly replace the front bumper on your Corvette with this handy, step-by-step guide.
This article applies to the C6 Corvette (2005-2013).
Replacing the front bumper on a car is often done out of necessity. Maybe you misjudged the distance between the front of your Corvette and that light pole, or perhaps someone crashed her/his bike into the front of it. Maybe, you just want to install a custom bumper that gives your C6 a more aggressive look. Whatever the reason, you'll be glad to hear that replacing the front bumper on a C6 Corvette isn't a terribly hard task and you can complete it yourself with relative ease. A bumper could cost between $200 (for used) to $800 (for a new one).
Materials Needed
- 10mm socket
- Panel puller or flat head screwdriver
Step 1 – Remove fender liner plugs and nuts
There are five plugs holding the fender liners in place. These plugs are located near the opening of the fender. Remove those plugs and pop out the reflector on each side of the bumper. There are also three 10mm nuts you must remove.
Step 2 – Remove screws from top of bumper
On the top of the bumper (beneath the weather stripping), you will find a series of screws. Remove these first. Carefully pull on the top corner of the bumper to pop it out.
Step 3 – Remove screws from bottom of bumper
Next, remove the two screws and two 10mm nuts underneath the bottom of the bumper. Pop out the other top corner of the bumper and close the hood. Then, pull the bumper forward.
Step 4 – Remove plugs on sides of bumper
There are two plugs on each side of the bumper. These can be removed using an interior panel puller or flat head screwdriver. Once these plugs are removed the bumper will come off. Carefully set it aside. Once this is done, the bumper should be free. Gently pull the bumper outwards. If there is any resistance during removal, double check the other for any missed clips or fasteners.
Pro Tip
Use two people to remove the bumper. It is not heavy, but it can be unwieldy.
Step 5 – Install new bumper
Repeat the first four steps in reverse to install the new bumper. First, replace the two plugs on each side of the bumper. Carefully push the bumper back into place. Re-install the two 10mm bolts and two screws on the bottom, followed by the screws along the top. Replace the fender liner plugs on each side and the three 10mm nuts.
Featured Video: How to Remove Chevy C6 Corvette Bumper and Headlights
Related Discussions
- Removing Front Bumper - CorvetteForum.com
- How do you Remove the Front Bumper - CorvetteForum.com
