5 Reasons the C8 Corvette Should Offer a Manual Transmission
Some drivers prefer the driving challenge of a manual clutch equipped transmission. Without one, they may avoid purchasing the vehicle altogether. To maintain Corvettes heritage and give customers a choice, here are five reasons why the upcoming C8 Corvette should be manually equipped.
More Power
Automatic transmissions lose some power through the process of gear reduction/multiplication. The large number of clutches inside the transmission combined with the loss of efficiency at the torque converter can reduce power output by five to ten percent at the wheels when compared with a manual. Sometimes it's hard to see the difference at the track because the fast gear changes of the automatic offset the reduced power.
>>Join the conversation on the reasons the C8 should offer a manual transmission here in Corvette Forum.
Easier to Upgrade
If you decide to do some modifications there will come a point when the transmission needs to be upgraded. For the most part, your manual transmission will only need a stronger clutch installed to keep it reliable. An automatic at the same power levels may require a torque converter, valve body modifications, and transmission control module tuning.
For information on maintenance and repairs of your C5, C6 or C7, visit our How-To section by clicking here.
