6 Best Bolt-Ons for the Corvette C3/C4/C5
Increase performance quickly with these popular bolt-ons.
Cold Air Intake
Cold air intakes are designed to funnel in air from outside the engine bay. They also include high flowing air filters. The result is a cooler intake temperature that can increase horsepower by 10-20.
>>Join the conversation on the 6 Bolt-Ons for the Corvette C3/C4/C5 here in CorvetteForum.
Exhaust
Exhaust systems include mufflers, catalytic converters, and headers. Gains of 15-25 hp can be made when modifying your entire exhaust. Depending on the type of muffler you choose, engine sound can be increased to your liking. Check to see if the exhaust you decide to purchase meets E.P.A. requirements.
Computer Reprogramming
Reprogramming allows you to fine tune your engines air/fuel ratio and adjust timing among many other features. When properly calibrated, owners can see horsepower gains over 30. There are a large number of programmers to choose depending on your price point. Remember to check whether your states laws allow computer programming.
Coilovers
No matter your Corvette's year, it can gain performance with quality aftermarket coilovers. Most coilovers can be adjusted to fine tune handling and ride quality. Height can also be adjusted.
Rear Gear Ratio
The rear axle gear ratio calculates to the amount of times your driveshaft turns in relation to your wheels. For example, a C5 Corvette factory gear ratio is 3:42. If you wanted to improve your acceleration, you could switch to a 3:73 or 4:10, but top speed will be reduced.
Electric Fan
For those corvette owners with belt driven fans, an electric version will reduce drag on the engine and free up horsepower. Electric type fans allow you to control when the fan turns on and off, making it easy to keep your coolant temperature at normal levels.
For information on DIY repairs, maintenance and modifications for either the C5, C6 or C7, click here.
