8 Ways to Make Your Corvette Stand Out From the Crowd
If you love your Corvette but are looking for way to truly standout, here are some tips and tricks to making your prized possession even more noticeable than it already is.
1) Upgrade exhaust system
Not that there’s anything wrong with the OEM Corvette exhaust system (in most cases), but if you want to turn heads on the road, consider going with a (loud) powerful new exhaust system.
2) Aftermarket body kit
Sure, your Corvette is noticeable, but if you really want to stand out with a car that is as unique as your personality, research after-market body kits for your particular model. There are probably plenty to choose from, and each comes with its special own accent to apply to your prized vehicle.
3) Replace your tires
While this might seem like a performance upgrade, if you go with the right looking tires for your Corvette, not only will the car handle better, it’ll look great sitting in the parking lot too.
4) Get new rims
Probably the most obvious solution for standing out with any car is to upgrade the OEM rims with something flashy and noticeable. Most Corvette drivers prefer chrome, but a popular option is colored options that complement the vehicle’s exterior.
5) Tint your windows
Want to be noticed but not seen? Well, a good solution is to tint your windows – there are do-it-yourself kits available, but truthfully, you’re better off having this service completed by a professional hand; especially for a vehicle as special as a Corvette. There will definitely be a noticeable difference in the final product.
6) Aftermarket seats
This is a trick not often considered by many, but when done, is noticed by everyone. There are a ton of aftermarket seats for every make and model Corvette available, so selecting one might prove to be an arduous challenge. Some things to consider – how you drive the car (if you use it every day, maybe you want comfort), and also the exterior color of the car – picking a colored seat that complements the outside will only enhance its presence.
7) Adjust your suspension and lower your Corvette
While a Corvette is already pretty low to the ground, you can get it even closer through some professional suspension modification. This’ll not only make the car look super cool when zipping around a corner, it’ll also improve its handling.
8) Replace the audio system
Okay, the Corvette audio system is actually pretty decent, but if you’re really looking to get noticed in your prized vehicle, consider your options when it comes to aftermarket audio systems. The right thump in your car’s hump will have people turning heads a block down the road before you even drive by.
