Lingenfelter Stage 2 Kit for C7 Z06 Makes 750 Horsepower
Looking for an upgrade to your C7 Z06 but not sure what to get? You might want to check out the newly announced Stage 2 supercharger upgrade kit from Lingenfelter. With it, you can expect 750 horsepower and 750 lb-ft of torque.
The setup is a complete package, taking into consideration cooling and factory catalyst protection. The kit includes Lingenfelter CNC-ported LC-4 cylinder heads, custom LT4 camshafts and headers, LT1/LT4 dry sump damper, Lingenfelter 9.2-inch 15 percent overdrive supercharger drive pulley, supercharger drive belt, 100mm idler pulley kit, high flow air filter, and 170-degree performance thermostat.
Having the setup professionally installed also means you’ll get before and after dyno testing to prove the results, along with special Lingenfelter documentation and a custom branded USB flash drive.
Pricing information is currently unavailable, but if you have to ask…
Comments ()
