LMR C7 Corvette Z06 Stage II Video Leaves You Craving More
By -
new LMR racecraft
I certainly don’t mind seeing (and hearing) those Late Model Racecraft (LMR) videos showcasing the tuning team’s stellar work as one beautiful Corvette after another roars out impressive output numbers on a dyno machine.
However, I’d much rather be watching pieces like the LMR video below, which gives you a much better feel of everything they pack into a car, along with rolling footage on the road.
LMR rear
This particular video is centered on LMR’s 2015 C7 Corvette Z06 – Stage II, which includes a host of custom features, like…
  • Custom Cold Air Induction
  • American Racing stainless steel headers with high flow cats
  • 2-pc Billet Housing 160* Thermostat
  • LMR (Overdrive) Harmonic Balancer
  • Gates Belt
  • Custom Grind LT4 Cam
  • Double Valve Spring Kit & Pushrods
  • Cam Phaser Kit
  • Crank Bolt
  • LMR Badging
  • Professionally Installed
  • Dyno Tune
The only issue is that the video leaves you yearning to see a lot more of this beast in action.
Chime in with your thoughts on the forum. >>
via [Late Model Racecraft]
Comments ()
