GM encouragement for C5 aftermarket parts
By now everyone knows there are some critical components that are now unavailable for the 97-2000 model cars, specifically the EBCTM(Brake Control Module) and the Steering Wheel Position Sensor. Is there anything GM can do to make a run of these rare parts? Or convince someone in the aftermarket too?
One other option to explore here is to provide a way to update the obsolete components to the newer system?
Thanks in advance...
Received 19,282 Likes
'20-'21-'22-'23-'24
Very good question and one that all 97-00 C5 owners should be interested in GM's response.
By now everyone knows there are some critical components that are now unavailable for the 97-2000 model cars, specifically the EBCM and the Steering Wheel Position Sensor. Is there anything GM can do to convince someone to do a run of these rare parts? Thanks in advance...
Agreed. I'd like to purchase both as spares.
It is my understanding that the early model EBCM's are imbedded in some type of epoxy that prevents even a knowledgable tech to fix these units. The late model EBCMs (2001 and up) can be fixed (in most cases) if they fail. Since the early EBCM's are no longer available, the only way a vehicle with a bad EBCM can be fixed is to find a unit off another early C-5 that has been salvaged.
The bottom line is, many early C-5 owners are driving their cars with no traction control ABS, because their EBCM has failed. This could be an area where the feds get involved should someone have an accident that can be traced back to failures of a unit that GM no longer builds or repairs.
Pro Mechanic
+1
Following along with this one as well. Will be interested to see if the OP gets an answer.
