[ANSWERED] How Does No-Lift-Shift Work - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > Ask Tadge > Ask Tadge
Reload this Page >
Ask Tadge Post your questions here for Corvette's Chief Engineer Tadge Juechter and then discuss the questions and his answers.
Old 10-09-2015, 04:48 PM
ElCid79
CF Senior Member
ElCid79's Avatar
Originally Posted by BJ67 View Post
Initiate the power shift at 6200, you shouldn't hit the rev limiter. The No lift shift starts to work when you move the shift lever. If you push the clutch in before you pull or push the shift lever it will go right to redline and hit the rev limiter.
Ahh. I will try again doing it this way.
ElCid79 is offline
Old 08-19-2017, 10:47 PM
vtirocz
Junior Member
Can someone confirm if this feature actually holds the engine speed at the point where the clutch gets pushed in at? For instance, for the purpose of testing it, could you go to 100% pedal in 1st gear, clutch in at 6000rpm, and the engine speed will stay there for some period of time even with the accelerator pedal to 100%?
vtirocz is offline
Old 08-20-2017, 09:06 AM
BJ67
CF Senior Member
The complete shift procedure (power shift) has to be done for the NLS to work, that's why its called no lift shift. By keeping the car to the floor in any gear and say at 6000 rpm you decide to just push the clutch in with your foot still on the floor, NLS doesn't work because it doesn't detect a shift.
https://www.corvetteforum.com/forums...hift-work.html
BJ67 is offline
Old 08-20-2017, 10:56 AM
vtirocz
Junior Member
Thanks for the quick response. When the feature is working correctly, does the engine speed hold at the point where the clutch was pushed in at AND gear lever moved to next gear? So if I were to test it out, I could go to 100% accelerator pedal in first gear, clutch in at 6000 AND shift to 2nd (let's say that's all done before engine speed rises to 6300), and the engine speed will stay at some speed less than 6500 (ie. not bouncing off rev limiter) for some period of time with the accelerator pedal pressed to 100% this whole time?
Does anyone have a good video that shows the feature in action?
I have a '17 Camaro SS that supposedly has this feature (as per the chief engineer), but when I execute a no lift shift the engine speed raises to and stays at 6500 RPM, which leads me to believe it's not working as intended on my car.
vtirocz is offline
Old 08-20-2017, 11:41 AM
BJ67
CF Senior Member
Lets say you perform the power shift when you see the tach needle somewhere after 6k and naturally well before 6500 rpm. The push (blip) of the clutch and the pull/push of the shifter into the next gear are done at the exact time and very quick. I do not know how any could be reading the small tach increments to see if there is any rpm change during such a critical time as you would be only glancing at the tach to make the shift and eyes back to looking out the windshield. The NLS is supposed to hold the rpm at precisely the rpm you performed the pedal blip and the push/pull of the shifter for that split second and as soon as the clutch pedal is back up the system is off. If at any time you change your throttle position from flat on the floor, the system is not activated.
If you could precisely make a power shift at 6k, the engine RPM should hold at 6k and you can hear it in the exhaust as a burble between each NLS power shift. That burble is I believe, fuel and spark interruption by the computer to hold the rpm from spiking.
BJ67 is offline
Old 09-06-2017, 11:36 PM
Mallett Z
CF Senior Member
Mallett Z's Avatar
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
In 2009, the ctsv and the zr1 vette had NLS, the Camaro zl1 had it in 2010. From what I understand, it was developed for the charged cars so the charge boost doesn't drop when you shift.
Do not know if it existed in 08, and not sure what year the naturally aspirated vettes got it.
I know for the Corvette, Launch Control and NLS were only on the 2010+ model years. It was not available on the 09's
Mallett Z is offline
Old 09-08-2017, 04:47 PM
StancyPants
CF Member
StancyPants's Avatar
As for the calibration part.. I speculate that the ECU is momentarily killing ignition/fuel to unload the engine while keeping the throttle open. This is how the quick-shifter on a motorcycle operates and it's generally the same principal for cars. The C7 probably receives some input to kill spark/fuel from the driver the moment the shifter is disengaged from gear.
StancyPants is offline
Old 09-12-2017, 01:47 PM
rb185afm
CF Senior Member
rb185afm's Avatar
Strangely, I could not get the function to work on the track. I loved it in my Gen 5 Camaro 1LE. Worked amazing. I tried for hours in my GS, on the straight at Buttonwillow, and continually bounced off the rev limiter. I ended up doing the old fashioned lift and was rewarded with better times.
rb185afm is offline
Old 09-17-2017, 10:13 PM
PeteC7
CF Senior Member
PeteC7's Avatar
Same thing here with my GS running in Track Sport 1. Tried it twice and both times it hit the rev limiter and made a very rough shift when I threw it into the next gear. Clutching is definitely more normal feeling but I kept my foot planted on the gas both times.
Actually I just reviewed my PDR video and one time it definitely bumped into the red but the second time it appeared to work?
PeteC7 is offline
Old 09-18-2017, 08:05 AM
BJ67
CF Senior Member
Can you state at what rpm you initiated the shift and how you performed the shift. Knowing the throttle was on the floor isn't enough information
BJ67 is offline
Old 09-18-2017, 08:08 AM
BJ67
CF Senior Member
Same question, at what rpm did you initiate the shift and exactly how did you perform that shift. Even if you perform a power shift 3 to 5 hundred RPM before the red line you shouldn't hit the redline
BJ67 is offline
Old 09-18-2017, 12:20 PM
PeteC7
CF Senior Member
PeteC7's Avatar
The first one hits redline, the second one seems better but the revs did still seem to increase. The process was gas pedal to the floor and at redline press the clutch in and shift quickly.
PeteC7 is offline
Old 09-18-2017, 01:04 PM
  #33
BJ67
CF Senior Member
https://vimeo.com/234348074
First of all you don't do a no lift shift /power shift at redline. The shift has to be initiated just before redline because of the time it takes to perform a true power shift. Also the tach is always behind the actual RPM, so if you initiate the shift at redline, you are already hitting the ref limiter at 6600 RPM. Just one more thing, listening to your shifts, they are way to slow. Try doing a super fast shift and blip of the clutch at exactly the same time at 6200 rpm, you should not hit the rev limiter even with out NLS
BJ67 is offline
Old 09-18-2017, 01:18 PM
  #34
BJ67
CF Senior Member
Default power shifting
Turn up the speakers and listen to how quick and violent a power shift is, if need a password to open the dropbox file its 567521.
https://www.dropbox.com/scl/fi/2umas..._RU6bUjBs&sm=1
BJ67 is offline
Old 11-14-2017, 09:15 PM
  #35
vtirocz
Junior Member
This same question was just answered on the 6th gen camaro forum in the similar "Ask Al" (chief engineer for Camaro platform) subforum:
http://www.camaro6.com/forums/showthread.php?t=513327
That provides more detail that I thought some folks might be interested in. I suspect the features are tuned very similarly between the Camaro and Corvette platforms.
vtirocz is offline
The Following User Says Thank You to vtirocz For This Useful Post:
Boiler_81 (11-26-2017)
Old 11-22-2017, 09:45 PM
  #36
slickstick
CF Senior Member
slickstick's Avatar
Good post... I thought Rev Match had to be on. It's a little unnerving to trust the system, thinking I'm going to blow the engine
slickstick is offline
Related Topics
Thread
Forum
Replies
Last Post
jvp
Ask Tadge
73
Yesterday 03:25 PM
speedy41
C7 Z06 Discussion
41
08-26-2017 09:35 PM
Kaged
C7 Tech/Performance
3
01-21-2017 01:30 PM
Forum Jump
Sponsored Ads
Vendor Directory
