[ANSWERED] Magnetic Ride Performance Calibrations
Does the $350 MRC update have any effect on safety, which is Stabilitrak (or “active handling”), and, ABS? The write-up only seems to mention handling, ride quality, and, driver confidence.
I’d just like to know if my 16 Z06 (when all safety systems are on) is just as safe w/o the update.
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
"So you sold my poor client a product you knew could be made safer!"
The update can't possibly have any effect on steering, stability control, or ABS systems. It's simply a re-flash of the MSRC controller whose only function is to adjust the relative softness/firmess of the MSRC shocks, in response to sensor inputs coming into the controller.
"Handling is more responsive and much more precise. The response of the vehicle is more exact reacting to driver steering inputs."
To me the steering is way too light in tour mode even without the update. That's probably what you feel as twitchy.
I had driven in Touring mode without the update and did not feel that it was as twitchy as after the update. That's why I expressed it in my review above. Other people may have different opinions, but that's mine. Hopefully my feedback is useful to other considering the update. The steering was just one part of my review.
It was a good review, thanks. I had driven my 2014 Z51 in Sport almost all the time (it was a non mag shock.) When I got my 2017 Grand Sport found Sport was a stiffer ride than my 2014 (as GM validates) so I drive in Touring. Felt the steering assist was too light so have it set in always Sport where it feels about the same as the 2014 set in Sport.
From your other comments, although my 2017 Grand Sport apparently has some of the new features I'll get the upgrade when available.
It sounds like you either didn't understand my point, or the effect on handling of various shock (damper) and suspension settings. MSRC settings don't influence steering settings per se, but of course, handling differences can fool you into thinking steering settings are different. A better handling car, will make you think steering has suddenly gotten more precise even though it hasn't changed. In that case, it's the suspension making it feel more precise.
I have a DSC Sport controller on my car, which by most accounts has a more dramatic effect on the MSRC system than even the latest OEM updates, and steering feel is light in Tour regardless of shock settings. However, even though the feel is light, I find my car's steering response to be very precise in Tour as well and not "twitchy" at all.
I've always felt that if steering is reported to be "twitchy" it's either because the alignment and suspension is not set up as well as it should be, or because one's driving style is "twitchy," AKA not as smooth as it could be. A firmer steering feel can help those folks who tend to be "twitchy."
Oh, I've now read it about 20 times because of my other questions posted above.
The steering is a sum of the influences that add up to the feel the driver has between the steering wheel and the tire patch. There are a lot of components that factor into steering “feel”. In this case we are talking about the dampers, which are one of the major components.
As I’ve stated before, MRC has a handling algorithm called Transient Roll. It can be tuned by steering wheel angle acceleration, lateral acceleration and vehicle speed. For each of these variables the front and rear compression and rebound are individually adjusted.
So the observations made above are not because the driver “thinks” or is “fooled” into thinking the steering is better, or has enhanced response, but it is because the steering feel has improved.
Relative to the car feeling twitchy, that is a factor on individual driving style. I have several friends with C7’s. As an ex development engineer, to a fault, I always observe their driving character. I rode 4 hours with the one who loves the steering in tour. He drove around 95% of the time with one hand using his thumb and index finger. The other extreme is a friend who uses 2 hands all the time with a pretty firm grip. He never uses tour because based on his driving character; he naturally feels the car is too light in tour which can also be defined as twitchy.
Great info! I definitely will be getting this next time I'm in at the dealership.
In a roundabout way, you’ve made Mero’s point.
I wasn't commenting on Mero's observations at all. As I also said, obviously a better handling car will have a more precise steering feel regardless of boost setting.
Will the updates be available for European models also?
I have a "European model" 2017 Z51 mag ride and I think this has a different setting than US version from the factory (harder damping setting). (also the bigger mirrors, headlight washers etc).
Will there be an update also for European models? Part of the reason why I did not buy an import vehicle is that I wanted the stiffer European suspension setting.
I like the settings today with big differences between Tour/Sport and Track modes but if there is an updated algorithm for it to be even more subtle in the three modes it would be welcome!
Cant wait for spring to take the car out of hibernation!
#33
Received 1,400 Likes
This is the kind of answer I like to see.
#37
I have gotten the update on both my 16 Z06's and am very satisfied with the improved ride in tour mode. Job well done Tadge and Jim. I also appreciate your detailed responses to questions on the Corvette Forum and willingness to entertain owners questions at the annual corvette bash.
Now if you could just improve the throttle response to be instant like a carbureted engine in acceleration and deceleration i would be smitten : )
#38
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,811 Likes
2015 C7 of the Year Finalist
This just came out for the 2014 MY. Since most all of the 2014s are out of warranty, the OP code is not allowing the labor to be charged to the installation.
Is this an error?
Is this an error?
#39
I had driven my non MRC Z51 C7 for 3 1/2 years and was used to the max throttle response since I drove in Sport. When I got my Grand Sport set the steering to always Sport and NPP to always Track. But no such option for throttle response. In fact for the 2017 I needed to have it in Track to get max throttle response. Driving in Track on the street will rattle your teeth!
Solved the problem with a Vitesse Throttle Controller! In fact I can set the Throttle Response far more aggressive than I have the Holley 850 on my 502 cid BB in my street rod! That 850 is a "Double Pumper" with two 50 cc accelerator pumps and the right pump cams (fast but not full volume dump) so it doesn't get too rich-but yet no bog or stumble! The 850 carburetor is cable operated but throttle-by-wire control is NOT the feature that is slower, it's the response programming! Note below a 25% foot peddle opening can open the throttle 50% if programmed to do it! The OEM is probably more like that shown, a 25% peddle opening only opens the throttle 12%!
This is a PDF of my install: http://netwelding.com/Throttle_Control.pdf
Below are a few pics from that pic/text doc.
In 2014 only had to drive in Sport to get max Throttle Response. It was a non MRC so ride was no issue but liked the Steering and "nanny response." In 2017 have to be in Track mode to get max response. After driving in Sport in my 2014 for 3 1/2 years my Grand Sport was NOT acceptable to me!
Note, in Touring where I drive the Grand Sport the throttle response is slow. Could set the Vitesse Controller to what I call "Boy Racer" at 9 but 4 or 5 setting is fine for me. At 5 feels like the 2014 set at Sport (= Track.)
#40
great explanation. There was no mention of an update to the c6 zr1s. Any idea why it would not be available for them?
