Ask Tadge Archived: Corvette's Chief Engineer Tadge Juechter answers questions from the CorvetteForum community.
LT1 engines across various models - how do they differ?
Old 01-20-2016, 10:18 AM
Kracka
Kracka's Avatar
Received 5,712 Likes on 2,919 Posts
Default LT1 engines across various models - how do they differ?
I am curious about simple, but possibly interesting question. The LT1 is now used in multiple models, the Corvette and Camaro. Are the actual engines identical in design and specs as they're built before getting prepared for installation (i.e. before manifolds, etc. are bolted on)? If they do differ, what differentiates the Corvette-specific LT1 from the others? While we are on the topic of the LT1, what was the reasoning behind the decision to bring back (or recycle, depending on how you want to look at it) the LT1 and LT4 engine designations. Thank you for your time and consideration!
Kracka is offline
The following 3 users liked this post by Kracka:
CPhelps (02-23-2016), Dogfather6 (01-20-2016), FYREANT (01-20-2016)
Old 01-20-2016, 10:45 AM
Dogfather6
Dogfather6's Avatar
That actually is a fantastic question and would love to see if there are any differences! Being interested in grabbing a Silverado at the end of this year (v8 but just maybe the LT1), having the '16 camaro 2SS I really would love to know the answer to feed my curiosity!
Dogfather6 is offline
Old 01-21-2016, 04:09 PM
CPhelps
CPhelps's Avatar
The LT1 is actually only used in the Corvette and Camaro.
The 6.2L truck engine is actually an L86.
I think the question is still interesting though, as GM's powertrain site lists some differences but I'm sure there are more. Plus it gives insight into the things they change for specific vehicle applications.
They have the same compression ratio.
LT1 revs to 6600 vs. 6000 for L86.
Materials listed (alloys unspecified) for the block, heads, intake manifold, exhaust manifold, main bearing caps, crank, camshaft, and con-rods are the same.
Things like cam specs are not listed, so it would be neat to see if they're the same and the different power profile comes only from intake/exhaust manifolds and tuning, or if the camshafts are different as well (which I suspect is the case).
CPhelps is offline
Dogfather6 (01-22-2016)
Old 01-21-2016, 04:58 PM
Kracka
Kracka's Avatar
Thank you for that clarification!
Kracka is offline
Old 01-22-2016, 11:04 AM
Dogfather6
Dogfather6's Avatar
Thank you so much for the awesome information! Much appreciated it!
Old 01-25-2016, 04:54 PM
Kracka
Kracka's Avatar
My original question has been edited to include Fyreant's question: https://www.corvetteforum.com/forums...on-reused.html
Kracka is offline
FYREANT (01-25-2016)
Old 01-25-2016, 05:19 PM
CPhelps
CPhelps's Avatar
One of the vendors, I think LG, posted pictures of a built in "catch can" in the LT1 Camaros. It will be interesting to see if C7 adopts that as well.
CPhelps is offline
Old 01-25-2016, 06:00 PM
Dogfather6
Dogfather6's Avatar
Correct, LG indeed find a built in catch can on the SS. Apparently, it isn't enough for people and are ordering/installing an extra one lol.
Old 01-25-2016, 06:26 PM
FYREANT
I'm Batman..
Pro Mechanic
Support Corvetteforum!
FYREANT's Avatar
Sounds good to me. I'd love this one to go through. I think this is just the type of question that the Corvette team likes to get.
FYREANT is offline
Old 12-21-2016, 01:21 PM
Chevette!?!?
Chevette!?!?'s Avatar
The Camaro and Corvette both use the LT1 engine But because of the limited space and low profile of the Corvette engine bay a different intake,head and oil pan are used. Otherwise the engine specs are identical.
Chevette!?!? is offline
Old 01-15-2017, 11:31 AM
tfuno
tfuno's Avatar
I have a 1970 LT1 block in my 77 C3. My understanding was the LT1 was a four bolt main block and the engine i have came out of a Caprice. So were other GM models installed with factory LT1?
tfuno is offline
Old 01-15-2017, 09:50 PM
BlueDevilZ51
BlueDevilZ51's Avatar
I'm almost positive the LT1 is the same in the Corvette and Camaro. They both have the same intake and heads.
BlueDevilZ51 is offline
Old 01-16-2017, 01:50 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just FYI, this section is devoted to questions regarding current production models.
69427 is offline
Old 01-22-2018, 11:52 AM
Dale002
Dale002's Avatar
The LT1 was actually first introduced in the 1970 Stingray.
Dale002 is offline
To LT1 engines across various models - how do they differ?
Quick Reply: LT1 engines across various models - how do they differ?
