HUD adjustability 2019 Z06
Hello Tadge,
I recently received my 2019/Z06 Vert on Saturday.
Its at the "detailer" now getting some XPEL, tint and Ceramic applied so I do not have the car until this Friday,but in any event while driving it the short distance from the dealer to the detail shop it seems that the HUD display is a bit out of level, it appears titled to the right horizontally, I searched the forum and found others who have a similar issue with respect to the HUD not being level when viewing it.
Is there a "LEVEL" adjustment available ?? Or is this a common defect that GM is aware of and has not resolved yet ?
If there is a easy fix where in the menu/settings would I find that adjustment. ???
Thank You
Thank You
Hey Guys,
Looking for a little info, the HUD Display on my 2019 Z06 has a rotational adjustment for leveling out the display besides the up and down for height viewing.
When the HUD display is viewed on my windshield in the "CENTER" of adjust ability which is at the Three O'Clock position its very, very out of level !!!
When I rotate the adjustment to Twelve O'Clock or full counter clockwise its still out of level by 10 to 15 degrees !!
I was hoping that there was a software re-calibration available to correct the adjust-ability and level the display correctly ????
If anyone can let me know how their display looks at the three O'clock position relative to level I would appreciate that info.
I am trying to see if this is a consistent defect in all the HUD's or if mine is just out of calibration/spec and needs a replacement if not software update exists.
Thanks in advance
Thanks in advance
Originally Posted by RidgeRunner0207
Hey Guys,
Thanks in advance
Thanks in advance
I sat in a few other new Vette's with HUD and they are almost level/tilt wise in the center of that adjust-ability, so I am assuming mine is either out of calibration ??
OR its defective, and cannot be adjusted properly, and needs a replacement.
I have to say its pretty disappointing that it even made it out of Bowling Green as defective as it is ????
The dealer tech said it looks straight to him, he is I assume brushing me off !!!
If there is no software fix or re-calibration then I must have gotten a unit someone dropped or must have been a Friday built unit before a long weekend, or maybe it was a Tuesday hang-over unit after a 3 day weekend.
Its maddening that GM had from 2014 to 2019 to get this car correct and its still falling wayyyyyy short of the Porsche's I own in both quality and service experiences.
I guess I need to see about getting a new HUD, then I can deal with dash squeaks, rattles, broken pieces, and general issues with the car moving forward.
If I could have re-ordered it, I WOULD HAVE REFUSED THE CAR !!!.
Thanks for the info !!!
