2017 Corvette OnStar
Hey guy I知 new to the site, but I知 very interesting of finding the OnStar location and how to get it disconnected on a 2017 Corvette.
Can anyone please help?
Received 5,213 Likes
Lots of related threads! For a start, never respond to anything, never pay them for anything, Never give them anything. At worst, all one is then stuck with is their most basic service for a while, but even that will die on it's own.
Received 8,927 Likes
If you don't pay them anything they turn off the system except for the blue push button if you want to call and sign up. They don't track your car and report to the insurance company unless you pay extra for them to do that.
Bill
Bill
Pull the fuse that is under the rear hatch floor mat or the actual OnStar box is located on the passenger floorboard kick panel (not the bcm which is on the floor). It will be on the right side upper kick panel, I think it says WiFi or something similar, you can just disconnect all the plugs and antenna and you are good but will have no Bluetooth or navigation. Hope this helps
Who cares, it's a waste of time to disable it and there are consequences to other functions you will want to use in the car like bluetooth... You drive with a phone in the car, don't you? Onstar is the least of my worries about being "tracked."
Don't just pull the fuse. You'll put a break in the car's internal data network and cause far more problems than you think you're solving.
If you absolutely have to disable it, pull the Onstar module out and remove the cellular daughtercard from it. Then put the module back in the car.
If you don't want to lose your Bluetooth, then the correct way to disable OnStar is:
https://www.corvetteforum.com/forums...right-way.html
