is this a good system, infinity kappa?
stock bose head unit with pac aeom-gm21
amp.....Infinity Reference 7540a
111W x 4 car amplifier
Details:
» 4-channel car amplifier
» 111 watts RMS x 4 at 4 ohms (139 watts RMS x 4 at 2 ohms)
» 278 watts RMS x 2 at 4 ohms in bridged mode (4-ohm stable in bridged mode)
» 2-, 3-, or 4-channel output
» variable high-/low-pass filters (32-320 Hz, 12 dB/octave)
» variable Bass EQ (0-12 dB @ 50 Hz)
» CEA-2006 compliant
» preamp- and speaker-level inputs
» preamp outputs
» 8-gauge power and ground leads recommended — hardware and wiring not included with amplifier
» 16-3/8"W x 2-11/16"H x 12-1/8"D
» fuse rating: 30A x 2
» warranty: 1 year
front speakers.....Infinity Kappa 60.7cs
6-1/2" component speaker system
Details:
» component speaker system includes woofers, tweeters, and crossovers
» 2-ohm system impedance (separate amp recommended)
» 6-1/2" Plus One+ woven-glass-fiber woofer with hi-roll rubber surround
» 1" M.M.D. dome tweeter with multiple mounting options
» Starfish™ mounting bracket for easier tweeter installation in factory locations
» 2-way external crossover network (18 dB/octave, 3,500 Hz high-pass and low-pass) with adjustable tweeter output settings
» power range: 2-90 watts RMS (270 watts peak power)
» frequency response: 45-25,000 Hz
» sensitivity: 95 dB
» top-mount depth: 1-15/16"
» warranty: 3 years
rear speakers.....Infinity Kappa 692.7i
6"x9" 2-way car speakers
Details:
» 2-way 6"x9" speakers (pair)
» 2-ohm impedance
» Plus One woven-glass-fiber woofer cone with hi-roll rubber surround
» rotating UniPivot M.M.D. dome tweeter
» computer-optimized outboard crossover with tweeter level control
» power range: 2-110 watts RMS (330 watts peak power)
» frequency response: 35-25,000 Hz
» top-mount depth: 3-1/8"
» warranty: 3 years
G'luck
Fej
so now i will be putting two 8'' subs in the rear and it looks like i can fit 6x9s in the front rockers. has anyone ever tried to do that in the front.
how will it sound with just 2 subs in rear and 2 6 1/2 or 6x9s in the front.
what are the best 8'' subs, i see you have kickers in yours. would you buy them again?
do i need 2 amps now, 1 for the subs and 1 for the front speakers or can i just use 1 amp for both?
thanks!
Fej
ok so as of now i'm getting 2 8" subs for the rear (thanks jeff)
2 6.5s for the front rockers ( thanks fej)
and for the amp..... i'm lost on which one to get, do i need to match the ohms for the speakers to the amp?
i'm ready to buy evrything now but i dont want to buy the wrong mismatched componets that i probably will without some help
thanks again guys
I like the Kickers, they are dual voice coils. I am running 2 amps. one for the 8s and one for the fronts, it sounds really good.
I am using Orion 225 HCCA amps (circa 1992)
