CD player in C5 broke
My CD player [In Dash] does not play properly. It skips like it needs
cleaning. I used a cleaner disc, did not help anyone got any ideas?
Re: CD player in C5 broke (USA1C5)
Not sure what your problem is, but one thing you need to be careful about and that is using "cleaner discs". GM recommends against using them in your CD player. Check your owners manual. It doesn't say WHY they don't want you to do it, but I think it may have a lot to do with the nylon dust protector in the CD slot on your player. Many cleaning discs have little "cat whisker" type brushes on them and they may wind up being torn off by the dust protector when inserted and end up in your player.
Check your CD itself. Try another CD and see if it does the same.
[Modified by Tx99FRC, 10:47 PM 8/8/2001]
