bose wattage
Re: bose wattage (ROD BROWN)
The 4 channel class A/B power amp in the HU that drives the Bose Twiddlers is about 15-18 wrms/ch. The 2 door class D power amps are 18-22 wrms/ch. These are estimates, but every amp is going to be slightly different. When the amps get hot, the power level changes. There are no DC to DC converters anywhere in the system, so all the amps run off 13.8 volts. All the amps have balanced or bridged outputs.
