Where to drill hole in firewall for amp power line, 86 corvette?
Re: Where to drill hole in firewall for amp power line, 86 corvette? (Smash)
Got the hole drilled, now where do I put ground? The amp is in the back of the car, against the rear wall.
I plan on putting it on the back wall, how much distance do i have before I hit the fuel tank?
I would put the ground the wall between the passenger and rear compartment. There is bunch of gronds just behind the passneger side about half way up.
As for mounting to the rear wall I never looked up to see how much clearance there is between the two. I usually mount my equipement using a thin piece of material on the other side of the carpet. I don't do any drilling through fibergall for mounting.
