Sponsored by: Innova
Note on component speakers
Old Sep 9, 2007 | 03:28 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Note on component speakers
I figure this is somthing worth mentioning since many of us have done this. For those of you installing component speakers, make sure to mount your tweeter where it will fire through the grille and not the door. Failure to do so will cause your highs to be blocked by the door panel.
Here the tweeter is blocked by the door panel
(alot of grumbling and cutting later)
The tweeter now fires through the grille
Additionaly, if your tweeter came with angle mounts, I highly suggest using them. You'll have to move your tweeter mounting location even closer to the woofer to get proper aiming but the end result is crystal clear highs.
Old Sep 9, 2007 | 04:27 PM
WKMCD's Avatar
WKMCD
Or you can mount them like I did and move the sound stage up.
Old Sep 9, 2007 | 08:59 PM
Kale's Avatar
Kale
or you can mount them like I did, and minimize path length difference and reflections.
Old Sep 10, 2007 | 04:00 PM
RUNNINGMAN 1's Avatar
RUNNINGMAN 1
Very clean look how is the sound?
Old Sep 10, 2007 | 04:36 PM
leolufse's Avatar
leolufse
Here is another option:
Old Sep 11, 2007 | 09:15 AM
Fasthotrod's Avatar
Fasthotrod
Or like this:
Or this:
Mark
Old Sep 11, 2007 | 10:46 AM
WKMCD's Avatar
WKMCD
I've got and AFR and FP guage on the pillar so I mounted them behind the door latches. Probably the 2nd best choice.
Old Sep 11, 2007 | 11:20 AM
Kale's Avatar
Kale
Nah, second best choice is kick panel type locations, but more mid panel. I think I'd rather put gauges in the door handles and hte tweets in the a-pillar to avoid all the sonic issues with tweets in that location. BTDT.
Old Sep 11, 2007 | 12:41 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Kale it looks like you beat the hell out of your tweeter grille.
Old Sep 11, 2007 | 01:14 PM
Kale's Avatar
Kale
hahaha yeah it does. It's just dust from sanding on that pillar. the grill is in perfect shape.
Old Sep 12, 2007 | 01:11 AM
Shangreer's Avatar
Shangreer
Really? In the kicks? When I first had my C5 installation done, I hated them in the door because I blocked them with my leg and, depending on how I moved my leg, the frequency response of the system seemed to change. I would have figured kick panels would be worse.
I ended up mounting mine on the dash, firing up at the windshield and wired them out of phase. They were pretty bright there, but sounded much better than in the bottom of the doors...at least to my ears.
I do love how yours are mounted, Kale. I am thinking about having my a-pillars in the C6 modified and moving mine there...still trying to decide if I like them mounted in the upper door or not.
Shan
To Note on component speakers
