I found this doing a search, but my wires are not color coded in this order. So how do I know which wire is the VSS wire?
You will have to tap into the harness on the instrument cluster. You need to find the Green/white (A7-circuit 817) with a tan/white (A6-circuit 33) above it and a black (A8-circuit 150 ) below it..The other green/white (A10-circuit 357) oil temp has a blank and a gray on each side.
