Sponsored by: Innova
Anyone running high output alternators?
Old Jan 1, 2002 | 10:05 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Anyone running high output alternators?
I'm using two Audio Art 100HC's. Fused at the battery at 150 Amps. One 100HC is running 2 ohm mono to sub, the other is running 2 ohm stereo. Total output should be around 1300 watts ( 100 amps@13.0 volts). Anyway I've using 2 ga cable (power and ground), upgraded alt to battery cable (2 ga), 1.5 farad Audiobahn cap, and upgraded dual 2 ga batery to chassis cables. I'v still got a little bit of the old light flicker going on right now. I'm dropping from 14.1 volts at idle to about 13.2 when I've got it cranked up. I'm ready to put the 220 amp single wire alternator i've got in. But was wondering if anyone else had moved to this addition? Thanks. Joe
