Sponsored by: Innova
C5 Z06 Sub only install
Old May 7, 2009 | 10:17 PM
chrisok1's Avatar
chrisok1
Default C5 Z06 Sub only install
Hey guys. I've got a couple of questions about adding just a sub to my existing Bose stereo. What all will I need in order to hook up the amp? I assume line level inputs but where do I pull a signal that has bass frequencies? Is there any kind of interface kit I need? The only time I have done a stereo was in a truck and everything was aftermarket, so we ran signal cables to the amps directly from the head unit. I plan on eventually doing the whole system, but for now just a sub/amp.
Thanks for the help!
Chris
Old May 7, 2009 | 10:43 PM
jdmvette's Avatar
jdmvette
Night Owl for life
if you want to add an amp to your stock system, you will need this interface that i just happen to be selling.
http://forums.corvetteforum.com/c5-p...aoem-vet1.html
Old May 7, 2009 | 11:20 PM
chrisok1's Avatar
chrisok1
Thanks! PM sent.
Old May 15, 2009 | 10:48 PM
chrisok1's Avatar
chrisok1
Got it! Thanks again!
Chris
To C5 Z06 Sub only install
