The unit worked fine after the install but the battery did go dead for a a few days. Now I have no sound in any feature. CD shows playing, Tuner showers playing. Any ideas? Or should I drive the 130 miles to have it looked at? Car is an 08 ZO6
Assuming you still have the OEM amp/speakers, replace AMP fuse #31 under the hood. If that doesn't fix it, take the dash apart and see if your radio is putting +12v out on the trigger wire when it's turned on. If you can find a different place (using these schematics)to check "antenna enable signal" for +12v that would work also.
Great idea on the fuse but that wasn't it. I will take the dash out tomorrow and see what I come up with. Thanks
