***FS: Barely Used BOSS CW150 2 Channel Amplifier CHEAP!***
NCM Bash 2008-2018
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
I have upgraded and needed a 4 channel amp so I don't need this one anymore. It is my barely used BOSS CW150 2 Channel Amplifier. It provides 2x50 watts RMS power into 4 ohms and 2x100 watts RMS into 2 ohms. This is a small nice little amp that can be used to power the rear speakers in a multi amp setup OR you can use it just to power the fronts and it will give you the capability to adjust the gains to match the volume level better in your car when contrasting between the front and rear speakers. I had it positioned up on the right side in my C5 where it was tucked away and hidden pretty well. (see picture).
It comes with everything just like brand new. Packaging, warranty card, everything.
The specs on it:
# Boss Audio CW150 Chaos Wired Series 2-Channel Car Amplifier
# RMS Power Rating: * 4 ohms: 50 watts x 2 chan.
# Max Power Output: 100 watts x 2 chan. @ 2 ohms
# MOSFET power supply
# LED power and protect indicators
# 2/1 channel operation
# High level inputs
# 2-Way system protection circuitry (thermal and speaker short)
# Soft turn on circuit
# Heavy duty heatsink
# Nickel-plated RCA level inputs
# Nickel-plated screw terminals
# Variable input gain control
# Frequency response: 12-22,000 Hz
# Dimensions: 6-1/4"L x 9-11/16"W x 2-1/6"H
Selling it for $25 shipped
I accept paypal
xtremevette@hotmail.com
Jeff
Where I had it originally in my C5 corvette.
The specs on it:
# High level inputs
I accept paypal
Jeff
