Pioneer AVH-4300DVD Wiring Question
So I am so close but need a little help. Doing a double din install and complete audio system re-do. Both amps, front components, rear speakers all installed and 100% ready to go. I am to the point of wiring in my HU and need a bit of help. I looked through about 100 posts on this issue but only found bits and pieces of information. Need someone to verify what I have found before I wire this puppy in. Please let me know if this is correct:
1) Remote "amp" wire (blue) = connect to white wire on b3 of wire harness.
2) "ignition" wire (red) = connect to fuse #22 @ passenger side foot well.
3) Dimmer wire (orange) = connect to creme colored wire on HVAC plug.
4) Parking brake wire (green) = I want to bypass requirement for parking brake to be set so where do I connect this?
The yellow and black wires I am running into my GM wire harness adapter I got from DD mods.
Can anyone help verify items 1-3 and answer question 4?
Oops, Oh yea I have a 2003 c5 Z06.
C5 schematics are available HERE
1) White wire at B3 is for C6, in C5 it's the dark green wire at pin 8 of C1. If you're replacing everything you don't need to connect that, if you're still using the door subs you DO need to connect it. The remote amp wire also needs to be connected to the trigger/remote terminal on your new amp(s).
2) Not sure what fuse 22 is, you can use the 3 wire pigtail for normal switched power or buy GMRAP or Accessory Valet to maintain R.A.P. controlled power.
3) Sounds right.
4) Go to AVIC411.com and find the 'bypass' instructions for your HU.
3) Sounds right.
3) Sounds right.
3) Sounds right.
Great! Thanks for the help.
