Aftermarket HU power tie in's
Ok, I am new at this and have a couple of questions. Any help would be greatly appreciated. Car is a 2002 Z06.
1. Can I just tap into the cigerette lighter for power and ground?
2. Fuse 22. i have read this to be an option. If I were to go here, how do I tie in to the empty fuse bay? What do I use to fasten the acc wire to the fuse bay? I tried connector ends, however they seem to lose.
3. Would there be any problems if I run the acc wire straight to the battery post?
I tied into the beige wire on the HVAC unit for the illum feed.
Any help is greatly appreciated.
Former Vendor
a gm harness
or keeping factory speakers and using a harness sucj as an roem-vet1(recommended) or the metra xsv1-2004?
here is some more info for you to see how things are wired
http://www.doubledmods.com/Installation.php
I am not using any harness's. Alpine HU, pdx 5 amp, 6.5 type r componets, and 5.25 in the rears.
I picked up a fuse majigger from canadian tire (10 amp). Plugges it in to fuse 22 spot, and using that for the power to the deck. I tapped into a ground from one of the harness's from the stock hu. I also used splitters for the rca's and a single set running from the sub rca spot.
Going to hook up the amp after super and test it with the speakers. If all goes well, i can start putting everything back together and mount the amp.
One question though. The illum wire from the head unit. I hooked it up to the beige wire from the HVAC unit. It seemed to work opposite for me. When I dimmed the dash lights the function buttons on the hu got brighter, so i just disconnted the illum wire. Where are you supposet o hook the illum wire up too? Not a big deal I guess, I dont use the dimmer anyway.
Factory radio/wattage
Would like to only replace the 4 speakers, in my 2005 C6.
About how many watts does the original factory radio, put out ?
Looking at 4 Focal 165's which have 90db sensitivity @ 1Watt. Could that unit work, until I save the money for a new head unit, amplifier and sub ?
Received 1,636 Likes
stymie222 (03-29-2019)
