Sponsored by: Innova
Help with C4 audio install please
Old Jul 1, 2011 | 12:38 AM
kruser0922's Avatar
kruser0922
Default Help with C4 audio install please
Hello all,
I am new to the forum. Thank you in advance for your help.
I just got a 1990 coupe a couple months ago and have been itching to upgrade the stereo. I have purchaed an Alpine CDA-105 for a head unit, a set of JL Audio VR 6.5" components for the front, and a Jl Audio G2250 2 channel amp to power the components.
I plan to start with just the components/amp up front and the head unit, then add a sub/amp later. I was thinking of JL Audio 10W3V3 paired to a JL Audio 500/1 for the sub/amp combo.
Here are my questions:
What are your opinions on my plans for audio equipment?
What is the best way to install the 6.5" components up front? Does anyone know of a slick way to do it or has anyone seen mounting plates for this purpose for sale?
The next question is what is the best way to go about installing the sub and amp combo in the storage bins? I have searched on the forum a fair amount but have found limited information for just how to go about it or if anyone sells an enclosure for the sub in the storage bin.
I am pretty handy when it comes to wiring and stereo installs but custom enclosures/mounting plates would be my weakness. I would just as soon purchase those items if possible or have some guidance building them.
I look forward to hearing your advice. Thank you!!
Old Jul 1, 2011 | 06:34 AM
Howielones's Avatar
Howielones
Default 6.5 are huge
I just did a complete install--my car is a vert though--but I went with 5.25's and used the original front enclosures after using the dremel on it!
JL audio is great and your combo will be excellent. You will need to read through some awesome posts here to fit the 6.5's.
I had bookmarked quite a few so if I can find them for ya I will try that.
Old Jul 1, 2011 | 09:32 AM
kruser0922's Avatar
kruser0922
I would appreciate that!
Old Jul 2, 2011 | 12:29 AM
GKK's Avatar
GKK
5 1/4" components will fit in the stock door sill speaker location with minor modifications. 6 1/2" components will require a new enclosure to be built. Also, 8" subwoofers will fit in the stock rear speaker area but, a new speaker mount will have to be made. There are no pre-built speaker enclosures available for the C4 Vettes.
I would buy a 4 channel amp with the two front channels powering the front components and the two rear channels bridged to power the two 8 ohm subwoofers wired in parallel + to + - to - for a 4 ohm load.
You can glue (use liquid nails) a 1/2" or 3/4" MDF board under the carpet against the rear wall to mount the amp or fabricate a false floor to mount the sub and amp for a cleaner look like this.
Tweeters are now mounted in the door panels.
Old Jul 2, 2011 | 10:35 AM
mfi's Avatar
mfi
that Alpine is on my maybe list as it has a very good chip in it..the chip is what seperates the good stuff from the rest!
Old Jul 5, 2011 | 12:06 PM
kruser0922's Avatar
kruser0922
GKK,
On the picture of the door sill, what size components do you show there? Did that particle board mount up to the surface of the factory speaker pod? Thickness of the particle board? Please give me a few more details on how things were accomplished in that picture.
Does the tweeter sound ok in the door sill location, or do i need to mount it elsewhere like you did?
Thanks!
Old Jul 5, 2011 | 12:10 PM
kruser0922's Avatar
kruser0922
Please explain what you mean by "chip". Audio processor?
I have the Alpine CDA-105 in my boat and it is a great sounding unit!
Old Jul 5, 2011 | 06:39 PM
mfi's Avatar
mfi
Yup, the processor is what makes the difference...
Old Jul 7, 2011 | 10:54 PM
GKK's Avatar
GKK
GKK,
Thanks!
The particle board mounts to the enclosure with a few short screws, the components are 5 1/4" Infinity Kappa's with the crossovers slid underneath the carpet behind the seats which are unnoticeable.
It's a very straight forward modification.
Old Jul 8, 2011 | 09:42 AM
kruser0922's Avatar
kruser0922
Thanks!
To Help with C4 audio install please
