Installing a Z140BH in a 2008 C6
not wanting to steal the thread, but I replaced my base model stereo in my 06 C6 and I used this adaptor: http://outlet.crutchfield.com/App/Po...px?I=120GMOS04
Is the sound quality going to suffer with thais one? If so which one should I use? Mine was base model, with no Bose. I ask because I am going to swap stereos since I am not happy with the kenwood I got
A head unit adapter is not going to suffer your sound quality. If/when you start a new thread, it would be advantageous to go further into detail as to what about the Kenwood unit you are unhappy with.
So I ditched the stock XM Antenna since it wouldn't work 50% of the time.
I have since mounted the aftermarket XM antenna in the rear (under the carpet near the locking mechanism (on the GIANT metal mounting bracket back there).
Signal works better, but still occasionally drops out.
The antenna right now is on an angle, I think if I find a flat spot back there it would work better.
Thoughts?
Thoughts?
On the C6 it's similar... but if I remember correctly there is a Styrofoam cover across the back there, I think? Here's a pic of the back of my C6 to show you want I mean:
You might be able to make up a small piece of metal that use adhesive to attach it back there, then put the antenna on top of it to maximize the signal. If you pull a tail light out, you'll see what I'm talking about... good luck.
In my C5 I had the Sirius antenna sitting on top of the rear bumper inside the fascia.
There's a pressure relief flap just behind the drivers side wheel hump, you can run the cable through there.
Thoughts?
Thoughts?
Corvette Enthusiast
ALSO:
I finally found out why my radio had opening problems! There is a plastic "nub" that the stock radio slides into. My radio was HITTING this! So I pulled the unit out, didn't disconnect anything. Broke a hacksaw blade into 3rds and manually sawed the plastic nub off. Afterward I dressed the sharp plastic in Electrical tape. Radio is now FLUSH with the Metra dash mount and NO more opening issues!
If you go with a large double din unit. Ditch the "nub."
Corvette Enthusiast
After doing that I noticed there is a lot more room back there for cables than I thought. So I guess my install problem was this "nub" all along.
Now that my radio is flush with the face plate the install is SUPER CLEAN and looks 100% professional. I'm super happy about it now.
#35
Corvette Enthusiast
I also dremelled the top slightly because it does "rub" a little bit. But it shouldn't keep the door from opening.
#36
As long as your installer removes the "nub" that the stock radio mounts back to in the rear then you can mount it perfectly flush with the face plate. There is no impediment to the door.
#37
The depth issue may or may not be there depending on how the cables and adapters are routed behind the HU. Some units have RCA's or a plug situated so they hit the plastic nub unless you pull the cables out of the way (or just get lucky).
IMO it's easier to just cut the thing off from the beginning.
#39
Corvette Enthusiast
