what kind of amp?
what kind of amp?
i would like to add a amp.i want to amp two 6x9s and a sub.i know how to wire the 6x9s but i want to know what do i do for the sub .do you buy the amp with that feature [subwoofer]or do i just take wires from the amp to the sub just like any other speaker.
Look for a bridgeable 4 channel amp. Use channels 1&2 for the 6x9s and bridge 3&4 to the sub. If the amp doesn't say bridgeable in the description look for 2/3/4 channel capable.
Most amps can only handle a 4 ohm load when bridged, so get a sub that can be wired for 4 ohms (single coil 4 ohm or dual 2 ohm).
PS. you may want to check your aftermarket deck to see if it has built-in crossovers too.
If your HU has separate RCA outputs just for the sub, then your HU does have some type of crossover that would only send out the low freq signals.
