couple of audio questions for a 1989 C4 coupe
Old 08-02-2012, 06:56 PM
rustyventure
rustyventure's Avatar
Default couple of audio questions for a 1989 C4 coupe
1. Is it possible to install a double din unit? The lack of search results suggests not, and I don't have a problem going with a single din. I have a nice navigation unit from my old car though, and I'd hate to waste it.
2. I have the Bose system in the car currently, but I'm going to remove it and put in a new stereo and new speakers. Can I use the existing wiring for the speakers ? I plan to start with 4x6 plates in the dash, and 6.5 inch in tthe rear
Thanks!
Old 08-02-2012, 08:57 PM
markcz
markcz's Avatar
1 - Don't know
2 - You could use the old wires, but why? It's very easy to run new speaker wires, and if you do an aftermarket amp it's required.
Old 08-05-2012, 06:58 PM
GrandSportRob
GrandSportRob's Avatar
This is who you wanna call if your going for a double din mod
http://doubledmods.com/
Old 08-06-2012, 08:57 AM
-=Jeff=-
-=Jeff=-'s Avatar
if you mod the center stack of components and cut/mod the bezel I think a Double DIN could fit..
Although it has been a long while since I had my 89 so I would suggest measuring first
Old 08-11-2012, 01:35 PM
rustyventure
You are correct:
Not counting any of the plastic mounts and such, there is exactly 4" between the bottom of the instument switches/lights, and the top of the A/C controls. So, a DDIN could fit. All I'd have to do is trim all of the plastic behind the dash that interferes, create new mounts for the stereo and custom mould new center console trim.
Sounds like a fun project to try someday. But for me, not today
To couple of audio questions for a 1989 C4 coupe
Quick Reply: couple of audio questions for a 1989 C4 coupe
