Has anyone put front speakers anywhere in a C5 besides the door??
I have 6 1/2" speakers in the doors that sound great and I want them to stay. I have 5 1/4" speakers in the rear which are really good speakers but are, well, 5 1/4" speakers (VERT). I also have a 10" sub in the rear compartment.
I just received a set of JL Audio 6.5" component speakers. I was going to consider mounting the tweeters behind the door opening lever, but where to install the mid bass??? I was thinking about the kick panels in the footwells but I have reservations about it. I know there is a big hole behind the passenger kick panel but I haven't checked the driver's side yet.
Any input????? I hate to not use such a nice set of speakers.
I also have 3 amps and the third amp is a 4 channel so I have an extra set of channels begging me to put them to use.......
On my C5 I mounted the tweets in the a-pillar cover, 1st & 2nd photo (these were Memphis "orbital" tweets, so they could move-pivot for direction). They sounded great and I also did this on my C6 back in Feb. First I tried the pods that came with the Focals (3rd), then found a molded set for sale (4th) ...
I have a set of Focal 165KRX2's up front. 6.5's in the stock door location, and I molded my tweets into the a-pillars (combo of pic 3 and 4 above). Custom fiberglass was new to me so I found some a-pillars off a junker on ebay. Smelled like $hit, but they were easy to clean and were in one piece.
As for your desire to fill all your channels, I have a coupe and my 5 speakers (including sub) provide PLENTY of high quality sound. I can't imagine having to tune more speakers in my coupe, let alone a vert with it's smaller space. I'd say start with the component set, I bet you won't even miss the 5 1/4's. If I'm wrong, then at least its easy to add the set in back.
ADD? As in more than two sets of drivers for the same frequencies? If so, why?
Will you be running active crossovers, time alignment, 32 bands of EQ, more than a simple stereo output, etc...?
What is it that you are looking to accomplish?
Please educate me on your thinking
I'm actually intrigued by Kale's statement.
If he is an expert than I would like to get his insight on this.
The statement was "well if you want the car to sound worse, just throw them in the kick panel, I guess".
This really doesn't explain anything but I still value his opinion if he has something to backup that statement.
FastHotRod asked some great questions. My system sounds excellent the way it is, but I DO have this JL Audio xr 650 component system with crossovers, and since I still have a free set of channels, I thought I would use them for more engulfing sound. I have 6 1/2" speakers in the front doors, but they sit down low (although I do have the tweeter pointing upwards) as all C5 front door speakers do. I don't want to mess up the door so I thought I might put the other mid bass in the kick panel and the tweeter closer to my ears.
I could sell them, I guess, but they really sound good still and I hate to not use them.
If you have multiple speakers playing the same sounds it can be tricky to get them all tuned properly. Especially if you only have the amp HPF/LPF available to adjust everything.
If you really want to try it, hook everything up with the speakers just sitting in the general location you'd mount them and see how it sounds. If you think it's better, then go through the hassle of mounting them in places not intended for speakers.
If it truly does sound great now, I'd have to agree that adding more speakers wouldn't be an improvment.
The crossover just makes the two speakers in the component set you're adding work well together, they may still clash with the one you already have installed.
Only if I do LP or HP will that cutoff frequencies!
I think you missed his point. The crossovers you posted a picture of are passive crossovers. The LP/HP crossovers in your amp are active crossovers. You can have one, the other, or both... it just depends on how you want to design the system.
In the case of your front component speakers, you are using a passive crossover designed to direct the low frequencies to the midbass driver, and the highs to the tweeter. If you are using a sub, then you should be using a high-pass crossover on the amp for the component speakers, set at approximately the same frequency as your subwoofer amplifiers low-pass crossover. (Perhaps 80 HZ?) That way, your front component speakers aren't being asked to provide sub-bass frequencies, allowing you to run more power to the drivers and allowing them to play slightly louder.
I asked a simple question and you have yet to answer it: What is it that you are trying to accomplish? If it's just to cram as many speakers into your C5 as possible, then go for it. But if you are looking to have a good sounding system, with the ability to image well and have a good sound stage while providing crisp, balanced sound... you're going the wrong direction.
I just figured out that I can't install them in the kick panels bacuse the left side has no open space. Guess I'll just have to sell them. Oh Well.
I was really hoping to utilize these speakers. BUMMER!!!!
NCM Bash 2008-2018
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
I put 3.5" in under my dash that aim out the corners...totally stealth but you can hear the midrange they produce beautifully. I have a 3.5" in the center too. I also run 1" tweets on the A-Pillars.
NCM Bash 2008-2018
