C5 Convertible Amp Placement Ideas
The amp is installed in the trunk passenger side storage bin. The audio shop told me that they had installed many systems with the amp located there and attached to the custom lid/protector, thus eliminating the need to screw into the body of the car in order to mount the amp. I had requested that they keep as much trunk space as possible so that I had room for my golf clubs/cart bag.
Last August, I blew the first amp completely. It continued to drain the battery and as a result, the shop replaced it with a new amp. The new amp has a shut off when it overheats and it has now shut off twice after about an hour of driving. Today it shut down and after we parked for lunch, I opened up the storage section and let it cool down. After an hour, we started the car back up and it worked fine.
As a result, I think I need to remount the amp somewhere else to prevent it from overheating. I would appreciate some suggestions and pics. I thought about behind the passenger seat, however I have a set of nice Vette Essentials seat covers and I don't want a heated amp to damage the back of the passenger seat.
Pics below of current set up.
Thanks!
I also have a heavy, Lloyds trunk mat on top of the compartment lids that may also be adding to the problem of overheating by acting as a blanket to keep the heat in.
I could always simply flip over the cover when I'm driving to allow more air, however that seems like more of a band-aid solution. My passenger seat is power so I can't install it underneath. Not too many areas in a vert to hide it. The back wall may be the best option.
I am sure SRQ knows this
but at the time you bought that amp ARC had A LOT of issues with the XDI amps and issues with them like your having. I know I had a few with the XDI 805
Since then they have corrected the issues and they are fine
mount it behind waterfall as well
You do need the newer type smaller amps, but this is the solution. I had mine behind the seats but was not car show good. The vette bin is perfect!
BTW: I'm looking for a sub with more punch right now. The 10w3 disappears going down the highway with the top down. If I raise the level, it will blast you out with the top up or when you slow down.
