I just purchased a 2002 z06 that was in the process of doing a double din install. So far everything seems wired up correctly and all I had to do was connect power to it. I tried fuse tapping #22 and connecting to the taped yellow wire by fuse box. Still get no power with key on. They did leave; mute, reverse and this random cream wire(directly off headunit) open with no attachments.
Kenwood DDX672BH Headunit
They used the PAC OEM-1 for the wire adapter. There is a random blue/white wire that comes off on of the harness with no where to connect.
It seems grounded correctly but I wonder if I could splice into radio harness and try grounding directly to that taped black wire?
