about 90% done with mine. I cut down the heat shield bolts and mounted the lc8 in the bed of it. Fits perfectly. That is going to 2 memphis viv 4 channels. All speakers are being replaced with helix drivers including the subs and tweeters. Im also adding a 10" sub.
what wires are you connecting to the input side of the lc8?? I know these units have a "summing" feature that integrates all crossedover signals to be pulled into one full range signal. Just curious as to what wires from the stock amp you would need to tap into.
you’re responding to a post from 2017 and he hasn’t posted here since 2018 I’d call it a lost cause unless someone responds with an answer, I don’t know myself.
