Can I use a line out converter on stock 07 Bose?
I am wanting to add a sub amp to the car but retain the factory radio. I know in previous cars, I was able to tap into the speaker wire to get a signal and then run the rcas from that. Can I do that on these stereos, and if so does anyone have the pinout?
I found this on another thread. I assume I could just tap into a couple these wires with a set of RCA's and get the signal that way? Essentially not even needing a LOC?
Left Front Low Level - Dark Green A9
Left Front Low Level + Tan A8
Right Front Low Level + Dark Green B11
Right Front Low Level - Light Green B10
Left Rear Low Level - Brown B9
Left Rear Low Level + Brown/White B8
Right Rear Low Level + Dark Blue A11
Right Rear Low Level - Tan A10
