I need an electrical expert - Backup Camera keeps blowing fuses
Old 06-23-2017, 03:42 PM
biggrizzly
biggrizzly's Avatar
2015 C5 of Year Finalist
Default I need an electrical expert - Backup Camera keeps blowing fuses
I installed a new DD HU a few weeks ago in my 2003 Vert, and the installation went without a hitch. Everything including the backup camera was working great for about two weeks. A few days ago I noticed that it stopped working. When I put it in reverse nothing happens. So, I was poking around threads about backup lights not working and I decided to check the 10AMP fuse on the panel on the passenger side. Fuse was blown. I replaced it and immediately it burned out again.
Any ideas what would cause this to occur suddenly when it was working properly before?
Any suggestions appreciated
Old 06-23-2017, 06:15 PM
Homer3D
Homer3D's Avatar
Where is the camera grounded? Might be a bad ground.
Old 06-23-2017, 06:33 PM
TorchRedFred
TorchRedFred's Avatar
Received 1,636 Likes on 1,121 Posts
Check your connections. Is there any wire showing, is it touching anything or are exposed wires touching each other?
To I need an electrical expert - Backup Camera keeps blowing fuses
Quick Reply: I need an electrical expert - Backup Camera keeps blowing fuses
