Questions about Sony XAV AX100 Install in a 2009 C6
Anybody here running a Sony XAV AX100 in a C6?
I just installed mine today with the PAC RP5-GM11 harness to connect to my car, followed the instructions to a T but I cannot get the steering wheel controls to work.
I've got a 3LT with Bluetooth, Bose and NAV (stock), keeping the Bose amp with the Sony setup.
I tried going through the Sony unit's menus to try and reprogram the SWCs but no luck.
I did find this thread (thanks google) on Sony's website about a 2010 GS owner who ran into a similar issue, and they recommended changing the PAC controller to setting 7 instead of setting 8 as they recommend in the instructions.
Just curious if anyone else here has tried that? I'd love some more info before I spend another couple hours tearing into the dash!
-Brian
-Brian
Sony Help Thread
So I dug back into it this morning and followed the recommendation from the Sony help thread listed above and my steering wheel controls work!
stuckMTB (07-24-2017)
But after some digging I found your post there and fortunately after having done it one, the fix was pretty quick the next morning. Got it done with much less sweat and cursing!
Thanks so much for sharing that!
-Brian
Did you by chance install a backup camera with your new radio? I'm thinking of adding one to my car but I can't find very clear info about wiring, and the stuff I'm finding is often contradictory.
Been about a month since my install and I'm a pretty big fan so far. My only complaint with the unit so far is somewhat slow boot times when the car starts up (3-5 seconds usually, sometimes a bit longer).
Just installed a backup camera to go with it yesterday, I would recommend doing this at the same time as the radio install if you're interested to save yourself taking apart the center stack more than necessary.
I really like the design of the radio though, it looks very well integrated in the car with OEM like appearance. The user interface and graphics are straightforward, clean and easy to use. I'm not a fan of some of the decks from other brands that have a bit of an 'alienware PC' look.
I would definitely buy this radio again if I had to do it over again.
Brian
Brian
how is the sound from it? Granted there are several factors in sound.. looking for general opinions..
I have an android in my car, while I like what I can do, it also is not a polished as I was hoping it to be
I'm pretty pleased with the sound. I listen to a variety of music, news, podcasts and audiobooks and the only thing I've noticed is that on some podcasts it can be a bit heavy on bass but I haven't played with the EQ settings to tune it out. Very happy with the performance on the music I listen to.
I've got Bose in my car, and I didn't change anything except for the head unit.
-=Jeff=- (08-21-2017)
