Factory Nav antena adapter for Pioneer Avic 8200?
Does anyone make a nav antenna adapter for Pioneer Avic 8200? What to use the factory Nav antenna withe the Pioneer but the connections are not the same.
Received 1,636 Likes
Yes, you need an aftermarket antenna adapter for GM cars. My Pac Audio wiring interface came with one in the package. You can buy just the adapter from Amazon or probably a local audio place or Best Buy.
Here is one on Amazon that probably should work. You can search "GM antenna adapter" and a few should come up.
I have the FM/AM antenna adapter. looking for an adapter for the factory bose Navigation antenna.
https://www.amazon.com/Best-Kit-BAA3...ywords=gm+baa3
Sorry, some how I missed the Nav part. I am not sure about the adapter for the Nav antenna. I don't think there is one? I would recommend using the one that came with the pioneer. I ran into the same problem with my 8200 but found out that most guys just stick it to the top of the head unit, or in my case I stuck it on top of the center vent under the dash. The nav antenna doesn't need to be seen and works just fine under the dash somewhere. You just want to make sure there is nothing metal covering it from above. Mine shows my location from under the dash and even when I am parked in my garage.
