Audio HELP! Trying to hook up amp lead line and speakers to 09380781 stock unit
Trying to hook up an amp lead line to 09380781 stock unit of my 2000. I don't know what wires to splice for power/lead/remote line(this is the line that connects to the amp that shuts it off when the radio is off, not the power line that connects directly to the battery from the amp) and rear left and rear right speaker wires. Help, please, my car is torn apart and this is the last piece i need to figure out!
You would need an adapter (not just a harness or simple splices) to provide the required interface between the OEM system and the new external amp. This is due to the way the factory system was designed.
The will do that and provide you with line-level RCA audio outputs to connect the amp
2000 Chevrolet Corvette Stereo Wiring
Constant 12V+ Orange
Switched 12V+Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Rear Window
Front Speakers 4" Kick Panels
Left Front (+)Tan
Left Front (-)Gray
Right Front (+)Light Green
Right Front (-)Dark Green
Rear Speakers 6" Rear Sides
Left Rear (+)Brown
Left Rear (-)Yellow
Right Rear (+)Dark Blue
Right Rear (-)Light Blue
Switched 12V+Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Rear Window
Left Front (+)Tan
Left Front (-)Gray
Left Rear (+)Brown
Left Rear (-)Yellow
The head-unit has 4 connectors in the back:
- C1 / C2 (which is a single siamese connector) - power, ground, BCM data, front and rear speakers
- C3 - power amp inputs
- C4 - pre-amp outputs
Corvette505 (12-29-2017)
As I mentioned above, it's not as simple as splicing because circuits could be damaged. The C5 Bose system is based on a modified Delco head-unit that uses pseudo-differential low level signals along with fully differential speaker level signals. The common signals are not standard and have a DC offset, so they cannot be grounded.
This is why the adapter I mentioned above is needed to safely take care of all necessary interfacing and make the process plug-and-play.
Yes, you won't need to cut any OEM wire. It is plug-and-play and will provide you with line-level RCA audio outputs to connect the amp, as well as a remote turn-on signal to control it
Corvette505 (01-02-2018)
