Sponsored by: DashLynx
ROEM-VET1 Wiring Questions
Old 03-25-2019, 11:20 AM
GCG
GCG's Avatar
Originally Posted by BrodysFRC
That makes more sense. Thanks for the explanation. I can splice the blue/white ROEM into the blue-blue/white connection also to enable me to use the provided loose blue/white wire exiting the ROEM module for amp signal, correct?
No, I wouldn't advise to do that. The Blue/White from the PAC is not used. I would loop its end and protect it with electrical tape.
Old 03-25-2019, 11:21 AM
BrodysFRC
BrodysFRC's Avatar
Originally Posted by GCG
It would be interesting if you could read the voltage in that wire with a multimeter with lights ON and OFF and report back.
What should I expect to see... like 0.5v difference with lights on and off? Not 0v to 12v?
Old 03-25-2019, 11:22 AM
BrodysFRC
BrodysFRC's Avatar
What is the loose blue/white wire with the connector crimped on it used for?
Old 03-25-2019, 11:29 AM
GCG
GCG's Avatar
It is not used in this specific application. Remember that these harnesses are bundled with the PAC device to cover more than one car model.
They have different types of Harness A, Harness B and Harness C that are "mixed and matched" to form different packages depending on the application target.
Old 03-26-2019, 08:30 AM
BrodysFRC
BrodysFRC's Avatar
FYI - I got my head unit wired into the car yesterday. First I probed the cream colored wire's pin on the far right position of the blue side climate control connector. I got 0 volts lights off, and as soon as I clicked the fog lights on I got 11.35 volts. A few pins left was more like 12 volts. So, I spliced into the cream wire and with the head unit powered it dimmed nicely when I turned the lights on.
Old 03-26-2019, 08:55 AM
huesmann
huesmann's Avatar
What do you mean by "a few pins left?"
Old 03-26-2019, 09:10 AM
BrodysFRC
BrodysFRC's Avatar
I was just probing all of the pins to see if the car was at 11.3 volts or not. One of the pins more in the middle of the connector had constant power and was about 12 volts. I did not bother to look at the wire color or exact pin location.
Old 04-01-2019, 07:14 AM
sirdano
sirdano's Avatar
Here is a question I post else where. Does anybody have low volume on their rear speakers? If yes how do you fix it? Did you bypass the roem vet1 or run new wires
Old 04-01-2019, 07:24 AM
huesmann
huesmann's Avatar
Mine seem OK volume-wise. Aren't there some pots on the box for adjusting stuff? Check this out: https://www.corvetteforum.com/forums...roem-vet1.html
Old 04-04-2019, 11:43 AM
sirdano
sirdano's Avatar
Got it and made a how to.
https://www.corvetteforum.com/forums...-roemvet1.html
Quick Reply: ROEM-VET1 Wiring Questions
