Sponsored by: DashLynx
Help with the "dimmer control" wire on a Kenwood DNX894S
Old 06-13-2018, 12:24 PM
jrprich
jrprich's Avatar
Default Help with the "dimmer control" wire on a Kenwood DNX894S
I recently installed a Kenwood DNX894S in my 03 Corvette using an Axxess adapter.
All is working well except for the lighting in the Kenwood at night.
I cannot dim the display using the stock dash light dimmer control nor does the KW lights dim if the headlights are On.
The unit remains at full daytime brightness all the time
On the KW wiring harness, the Orange/white wire is clearly labeled as "Illumination Wire".
I connected the OW from the KW to the OW from the Axxess wiring harness as directed by the Axxess wiring instructions.
But I get no reduction in brightness on the KW display regardless of the position of the C5's dimmer **** or if the headlights are on.
Thanks in advance for any info
Jim
I think I found a solution after a long search online. Seems MANY have sought this same question. So I tapped the Brown wire behind the Trunk Release/Fog Light switch and ran it over under the bezel. Testing shows it to produce 12v when the ignition and lights are On. I think this will work as a trigger to the Orange/White Dimmer wire that comes out of the Kenwood harness.
Old 06-18-2018, 06:45 AM
BRAVO1
VETERAN
Support Corvetteforum!
BRAVO1's Avatar
I connected the brown wire also but no reduction in light........
Jim
Old 06-18-2018, 09:30 PM
huesmann
huesmann's Avatar
Supposedly the light yellow wire on the dual-zone automatic HVAC panel wire loom is also illuminated 12V, but it didn't work on my install. Maybe you need to have the engine on to dim (wasn't able to start motor when I tested)? But that doesn't make any sense because the lights on the HVAC panel came on, but the head unit didn't dim. Weird.
I think you need a source that doesn't dim with the dimmer switch, which I think the HVAC panel does. So something like headlights or parking lights. Not sure best way to connect to those.
Old 06-18-2018, 11:29 PM
jrprich
jrprich's Avatar
Jim
Which brown wire did you use?
The selected wire has to produce 12v when the parking lights are turned on and no voltage when the parking lights are turned off.
But this could be a Kenwood specific requirement.
Old 07-05-2018, 12:58 PM
jrprich
jrprich's Avatar
I ended up using the brown wire attached to the Fog Light/Rear hatch button.
Testing showed it does produce 12v once the parking lights are turned on.
It does cause my Kenwood DNX894S to dim just a bit.
Wish I could find a way to dim it more at night.
Jim
Old 07-09-2018, 08:09 PM
Oh Boy
Oh Boy's Avatar
Ok this is very simple assuming your dimmer function is hooked up and working on your Kenwood. Go into your setup page and look for monitor setup or similar option. While you are in that page look at what your settings are at (Brightness, Contrast etc..) Turn on your headlights and now adjust what you want those settings to be. That is what the screen will look like when dimmed. Turn off your headlights and you will see the screen revert back to the way it was.
jrprich (07-11-2018)
Old 07-11-2018, 11:20 PM
VinceC5
VinceC5's Avatar
from the axxess manual:
  • Tape off and disregard the Orange/White wire, it will not be used in this application.
  • If the aftermarket radio has an illumination wire, connect the Orange wire to it. Note: There are (2) illumination wires. If the Orange wire on the 24-pin harness is populated on the factory side, use that wire instead.
Old 07-13-2018, 02:03 PM
jrprich
jrprich's Avatar
Oh Boy,
Sorry for the reply delay, I had to get a pacemaker installed (now I am officially an OLD man) and that took me away from car issues.
I did just as you suggested on my Kenwood and it worked like a charm !!! a great big THANKS to Oh Boy for the clear set of instructions!
Thanks so much,
Jim R
Old 07-14-2018, 10:17 PM
Oh Boy
Oh Boy's Avatar
Oh Boy,
Thanks so much,
Jim R
Glad I could help and hope you are now feeling better! Good luck.
To Help with the "dimmer control" wire on a Kenwood DNX894S
Quick Reply: Help with the "dimmer control" wire on a Kenwood DNX894S
